Can't delete Email/Notifications Customizations
I recently migrated from ISY994i to Eisy and I was trying to clean up some old customizations that I no longer use.
I used the Admin Console, went into Configuration->Emails/Notifications->Customizations
I select one of the customizations, select Delete and it seems to go away. I also click Save.
Then I switch to Settings/Groups and then back to Customizations and lo and behold the customization which I delete is back again.
I made sure that the customization is not used by any program.
Is there a "proper" way to delete customizations or is this a bug?
You followed the correct procedure. Try reboooting the eisy and if the customization is still there, at the bottom of the window click delete then click save.
Let me know if that worked
No that didn't work. Every time I reboot the deleted customization is back again. If I try and delete it again and save and immediately reboot, it comes right back again.
@leadfoot interesting. I just created a new customization and reloaded IoX Java Admin Console and it deleted just fine. It's an outside shot, but I might clear java cache (be sure to check all 3 boxes) and download a fresh start.jnlp file (delete any old start.jnlp or admin.jnlp files). I wonder if it's a random cache/visualization bug - that has happened in the past.
What IoX version are you currently running? (Please give actual number, not just "latest/current").
What Computer OS are you using?
Make sure you are logged out of any PG3 or eisy_ui web interfaces while in Java Admin Console.
I cleared the java cache and downloaded a fresh start.jnlp from
https://isy.universal-devices.com/start.jnlp
I'm pretty sure I am logged out of eisy-ui and PG3 sessions...I don't have any tabs open with either of them. I restarted Admin Console and tried deleting a customization again and it came back again even after rebooting. I tried using the customization I deleted in a test program and it worked.
The version from the Help->About menu is 6.0.4 for UI and firmware. Is that the IoX version?
I am running Windows 10
I've opened a support ticket
Edited by leadfoot
added fact that I opened support ticket
Yes. Thanks.
Please post what support steps are completed to correct this issue, if you can. This is strange that it's unable to be deleted. How many customizations do you have?
Since you mentioned you migrated from ISY994 to eisy would you also try clicking/opening each one (slowly). Then hitting save. Just close IoX Admin Console (don't reboot the device). Then log back into IoX Admin Console and try deleting again. It's a long shot, but I know that Network Resources needed to be opened and saved in the migration steps. I wonder if it might help/work on the customizations as well.
