Updated Software Available!
Hello All,
I am happy to announce a set of updated software and OS for your eisy/polisy:
OS v14.3p9
  • Security update
UDX - v4.4.0_6
  • Support for manual static ip config
  • Increase message queue size for mqtt
  • Apply log viewing permission for udx/isy logs
  • Added additional python prereq packages (jiter)
  • Auto download Matter PAA certs
IoX - v6.0.5_1
  • Improved Matter support
  • Fixed programs timing during startup
eisyui - v0.10.1
  • Navigation & Organization: Expanded the Node List to include support for Folders and Groups (Scenes).
  • Groups/Scenes: Added a new Group Member Widget and detailed Scene Member Responder Links for improved visibility.
  • Program Updates:
    • Added visual identifiers with new Program Icons and Program Badges.
    • Enhanced Program Action Details to display all available command parameters.
  • Optimized UI for mobile devices
  • System/Logs: Added log download
  • Support hooks for AI (OpenAI and Claude)
  • Bug fixes
IMPORTANT NOTES:
  • If our IoX Version is below 5.9.1, do not upgrade as your unit may get bricked
  • Backup your unit before attempting any upgrade. This is CRUCIAL
  • It's best to backup using eisyui.
  • Upgrade MUST be done when you are local to your unit AND using the Admin Console
  • If you are using Matter devices, they might not work after the upgrade. In that case, you need to restore your backup using eisyui.
