April 16Apr 16 Just installed 6.0.5 from 5.9.1. Took under 15 minutes, wow. Impressed. Did have to exclude and include some very old Zwave devices, but I am up and running. eisyUI was nowhere to be found as a service on the box. Got some great help from a support ticket, ran sudo pkg install eisyui and sudo service eisyui start and after a reboot the web page is running.I use a reverse proxy (Nginx Proxy Manager or Caddy) for all my internal services so that I can use domain names instead of IP addresses with an SSL cert. This is not working as the eisy tries to connect to Polyglots port 3000 as a redirect in order to serve up that site also. Here is the error:"An error occurred during a connection to eisy.mydomain.com:3000. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG"Has anyone successfully configured Nginx Proxy Manager to act as a reverse proxy for the eISY web admin?
April 17Apr 17 Not directly what you asked, but if you are a portal user, you can now access it remotely that way.
