I3 Paddle 3 Way w/2477S - works fine flashes red
Hi all,
I have successfully installed my first I3 Paddles. I have them configured in a 3 Way with a 2477S via a scene defined via the Admin console for my EISY. Both objects are controllers in the scene and I moved both of the nodes for the I3 to the scene.
Everything is working fine - both ends of the 3 way turn the lights on and off and I can also dim the lights (I set the I3 up as dimmers).
The only issue is that when I use the 2477S to turn on/off the lights - the in device light flashes red a few times after the action has been performed.
I cannot find anything wrong with the setup in the Admin Console.
Does anyone have any thoughts about how I can trouble shoot this red flashing a few times after using the switch?
