16 minutes ago16 min The failing solaredge plugin has been removed from the production store.The new updated version (now 1.1.8) has been installed in the production store.If you are using the original Mike King version, you cannot just do an update, you need to delete it in the PG3 dashboard and install this new version which has a different plugin ID.You will also need to re-enter your api_key in the custom configuration parameters using the key "api_key" and value of your actual API key.
