June 1Jun 1 Has anyone else had issues over the weekend not being able to access the web based UI for the eisy? Worked on Thursday for me but today won't allow me to log in however I can log in using the Java version. It says on the website invalid credentials but even if I try and do forgot password it never sends me the link. Again using the same credentials allows me to get in and make changes via Java.Side note, on Friday my Macbook Pro did a OS update.
June 1Jun 1 @BVincent be sure that you are using your UD Portal credentials when logging into eisy_ui. If you are able to get to the login screen then it's working. If it's just an invalid credentials error then you're possibly using the wrong user/pass combination. I've never tried the "forgot pass", but make sure you're checking your SPAM/Junk folder too.
