Wednesday at 02:34 AM2 days Nearby lightening strike knocked out my 15yr+ old GTO 2000xls pro opener and my 2 yr old I/o link. Have been Using the relay side to open/close the gate from UD MOBILE and using sensor to turn lights on for the carport and driveway. New GTO board doesn't have a N/O dry relay. I replaced both fried items, but my io link sensor doesn't ever change state (relay works fine). So , the program to turn on lights doesn't execute( see attachments for connection). ChatGPT suggests that I add a 12 vdc relay module in between the GTO board and the I/o link. So I'm thinking that I should buy the Aediko relay and power it from the gate lock contacts and use its n/o relay to create sense that the gate I has been powered from off to on (see attachments). Does that make sense to you?Final question: Given this is the 2nd time a lightening strike has fried my I/o link and gate board, would placing a ground rod on my gate do any good? My electrician thinks the aluminum posts, sunk 4 ft into ground should suffice. IDK, lightening keeps frying this equipment??! Aediko_Relay.pdf GTO2000xls_Outputs.pdf
Wednesday at 03:17 AM2 days If commands are reaching the gate, but not the other way around, I would try right clicking on the device and pick restore device in iox
Wednesday at 02:18 PM1 day I'm not sure this is helpful, but you can use 2 outdoor on/off modules to control a linear actuator.Scroll down to see my post here: https://forum.universal-devices.com/topic/45156-seeking-advice-on-controlling-linear-actuator/#comment-394531Turn on the first module, the gate opens. Turn on the second module, the gate closes. Turn them both on (or off), nothing happens.Ross
Wednesday at 03:49 PM1 day Author Thanks Paul for the suggestion - tried it no luv. The sense side of the I/O link is not getting an on/off message from the gate board. The gate lock terminals are sending constant 12v rather than toggling open/close.Not sure my current plan would change things by addition of a dry relay. The lock terminals will simply supply power. I need to connect something from the gate board that tells it to change state when the gate is opening/closing Edited Wednesday at 03:50 PM1 day by shergenr Clarity
