Comparing sensor temperatures
Just got my first Polyglot plugin running to get data from my WS-5000 console. I can figure out how to trigger a program when a sensor reaches a particular temperature. What I would like to do is to trigger a program (which opens a window and turns on a fan) when the temperature on the main sensor (outside temperature) is lower than an inside sensor's temperature, and close the window when the opposite is true. I would want to build in a few degrees of hysteresis to prevent too much cycling between open/close.
Is this possible with EISY and Polyglot?
Solved by larryllix
Calc Delta (enabled)
IF
. . . .temp1 < 9999
. . .OR
. . . .temp2 < 9999
THEN
. . . .$intVar = temp1
. . . .$intVar -= temp2
. . . .$sdeltaTemp = $intVar do NOT calculate in variable that continuously triggers CloseWindow or OpenWindow
ELSE
CloseWindow (enabled)
IF
. . . . $sdeltaTemp > 2.0
THEN
. . . . do close window process
ELSE
OpenWindow (enabled)
IF
. . . . $deltaTemp < -2.0
THEN
. . . . do open window process
ELSE
ANYTHING IS POSSIBLE with polisy or eisy.
@mikewu99 Nothing to add, but how is your window automated? I started this incredible journey with automating the (16) windows of my summer room in mind. I replaced the horrid windows with casement windows, but the original inspiration is unavailable/obsolete, so this project has been very back burner. Thanks.
@larryllix the programs are working after I figured out that $sdeltaTemp needs to be a state variable (I assume that's what the "s" prefix means). I added code to disable OpenWindow and enable CloseWindow when OpenWindow runs (and vice versa) to prevent the window motors from being energized every time the temperature changes. Also prevents the ISY from overriding me if I manually open or close a window.
Edited by mikewu99
