Sunday at 04:58 PM1 day I cleaned up my hue emulator setup, turned off a lot of unnecessary SPOKEN=1 devices and renamed some of the scenes. Now when I attempt to assign a Hue Emulator Scene to a harmony companion home control button, the software crashes. I have tried a lot of things, but can't get it to work. This is with two different hubs. Anyone else experience this and have a work around (hopefully not factory resetting the harmony hub)?
Yesterday at 01:37 AM1 day What software crashes? The node server or Eisy? Since you're using a node server, I'd start there and check it's logs if you haven't already. It's been a long time since Ive used it but I believe you can go to the hue emulator plugin and go to the logs tab. If nothing shows, set it to debug and post your errors.
Yesterday at 02:47 AM1 day Author Sorry for the bad write-up - the Harmony Software crashes, not the eISY or node server - so I can't assign the Hue Emulator Scenes (with spoken=1) to the home control buttons
