August 31Aug 31 I have been using the ST-NuHeat Node Server flawlessly for years. I have the Node Server running on a POLISY which talks to my ISY994. After a reboot the ST-NuHeat Node Server doesn't seem to authenticate to the NuHeat API any more? I know the NuHeat API changed recently for the Signature Series Thermostats, not sure if that has something to do with it, would seem to be? I know my credentials are correct as I can log in via the NuHeat iOS App? @simplextech any ideas, I assume you can recreate the issue? Edited August 31Aug 31 by jwagner010
September 1Sep 1 @simplextech isn't around anymore and isn't maintaining his plugins. He passed them all over to me and I do my best to maintain them.I don't have any way to reproduce this issue as I don't have the hardware or an account. But if you can switch the logging level to debug, restart the plugin, download the log and send it to me (a PM is fine), I'll take a look at it.
Sunday at 05:10 AM2 days looks like there is a now authentication needed Changelog - OpenAPII have the same issue BTW
Sunday at 10:34 AM1 day Author The node server is no longer supported by the original developer and @bpwwer had agreed to maintain it, but appears this would be more of a re-write, a lot more than maintaining the node server. So I suspect we are out of luck unless there is some else that has the time and knowledge to do a re-write of the node server.
Sunday at 02:27 PM1 day i have contacted nuheat to see if I can get the credential to access to thermostat. If i get it I'll take a look how big an effort it will be to rewrite it
Sunday at 11:09 PM1 day @Panda88 If you figure anything out, let me know. The plugin interface does have the ability to do oauth authentication which is what the new API needs, I believe.
