Sunday at 08:46 PM3 days Hi all, I am a new HomeKitHub user. I'm a long time ISY/Eisy user but new to this plugin. I bought the plugin to integrate my Hunter ZenTech smart fan/light combo into UD so that I can control the light in scenes. The implementation in Apple Homekit had two separate sub-nodes for the fan and light, with the ability to switch either on/off, brightness control for the light, and fan speed and rotation direction for the fan.I was able to pair the fan/light with HomeKitHub and successfully generate nodes (after upgrading to pro and enabling node generation) but there is only a single light node. The on/off control turns the fan on/off (no speed control) and the Brightness control can be used to turn the light on and off by setting it to either zero or non-zero values. So, I can do most of what I need to do, but functionality is limited due to this limited model for the device. The biggest problem is that I can't add the light to a scene, but will need to run a program to control it.Is this a known limitation? Any plans to enhance this to match the Home model with two sub-nodes. Is there a manual tweak I can do to get a better model?Thanks,Bret
Tuesday at 06:26 PM1 day The HomeKitHub implementation was targeted to get Ecobee Thermostats working again since Ecobee removed access to their API. But the intent is to support other devices as well. Please restart the plugin then wait a few minutes, then go to the Plugin's Log page and click "Download Log Package" then email that to me at JimBo.Automates@gmail.com and reference this thread.
