11 hours ago11 hr I have not yet found a means to copy a program text on EISY-UI, so I have a screenshot.I have a program that has been in place for several years and has worked as expected. I wanted a program to close blinds at 8pm or sunset, whichever is later and this program has done so. It has even worked as recently as a few weeks ago. No changes have been made since first creating it.The program is below. I expect this program to trigger at sunset, 8pm, and 11:59pm. Tonight (it is now 9:41)The program shows last run at 7:36pm (presumably the calculated sunset time) and ran false (expected). I expected this program also to trigger at 8pm and evaluate true. Yet, it apparently did not. Blinds are still open. Last run at 7:36 was false.Did something change in the program logic execution recently? Am I missing something?
10 hours ago10 hr Which version are you running? At some point a sunset/sunrise issue was introduced and I think it’s fixed in the staging repository versions.
3 hours ago3 hr Author 7 hours ago, hart2hart said:Which version are you running?I am on the latest Beta version. At this point, I do not know how to check the time or sunset time or location from the EISY-UI, but I must assume EISY-US-predicted sunset was 7:36 and logs show that it ran at that time. I do not know why else it would have ran at that time.One of my questions is why, regardless of sunset, did it NOT run at 8pm?
53 minutes ago53 min @oberkc , I know you said this program worked previously, but...Shouldn't the sunset trigger be an "or" instead of "and"?
