Insteon Open - Closed Sensor 2843-222 Outdoor Case
Hi there Everyone..
I was wondering if anyone has successfully mounted a Insteon open/close sensor outdoors.
I'm looking to put one on my side gate and looking for a simple solution like a waterproof case that fits nicely. Figured I'd check with the community here if someone has done this.
I have a few of these sensors already so hopefully I can put them to good use :).
Thanks in advance for any thoughts!
Stan
Used a couple of these mounted in a small dry box. Worked well for long time. Replaced with YoLink outdoor contact sensors after they failed. YoLink devices are great.
Thanks.. I have YoLink monitoring all my refrigerators and freezers and they work great. I have like at least 3 or the Insteon devices. Any idea what box you used for the Insteon?
