September 23Sep 23 With eisy-ui coming along and the Admin Console going away eventually, I figured now would be a good time to ask about this. I have a number of scenes where I update the action response to battery operated motion sensors, so on every boot of IoX (or ISY from 5.x onward, this worked without issue in 4.x) I have to go in and manually disable automatic writes to battery powered devices, otherwise over the course of a week or so the performance goes off a cliff due to all of the pending writes.Does anybody have a way of doing this using a program? The option isn't in the eisy-ui at all, and frankly after years of this it's getting old and I want to remove one more, "After power loss.." things from my life. Edited September 23Sep 23 by jec6613
September 23Sep 23 46 minutes ago, jec6613 said:With eisy-ui coming along and the Admin Console going away eventually, I figured now would be a good time to ask about this. I have a number of scenes where I update the action response to battery operated motion sensors, so on every boot of IoX (or ISY from 5.x onward, this worked without issue in 4.x) I have to go in and manually disable automatic writes to battery powered devices, otherwise over the course of a week or so the performance goes off a cliff due to all of the pending writes.Does anybody have a way of doing this using a program? The option isn't in the eisy-ui at all, and frankly after years of this it's getting old and I want to remove one more, "After power loss.." things from my life.I don't follow, maybe attach an image of the scene or program being used. Batter devices need to be awake to write, so writing is not something that should be done programmatically in most cases.
September 23Sep 23 6 minutes ago, Javi said:I don't follow, maybe attach an image of the scene or program being used. Batter devices need to be awake to write, so writing is not something that should be done programmatically in most cases.What he's asking about is if we could add a way to programmatically enable/disable automatic writes to battery powered devices. By default this is enabled, and IoX tries to write the updates periodically, which slows down other Insteon communications. In admin console, this is triggered here:
September 23Sep 23 Author 2 hours ago, Javi said:Ok so is the issue is the selected state does not persist after reboot?It doesn't persist, and there's no way to programmatically set it. Either would fix the issue.
September 24Sep 24 Perfect, I added an issue for investigation. ID: /udi/issues/21We have a backlog currently due to eisy-ui roadmap, but have replicated the issue.
November 9Nov 9 On 9/24/2026 at 7:07 AM, Javi said:Perfect, I added an issue for investigation. ID: /udi/issues/21We have a backlog currently due to eisy-ui roadmap, but have replicated the issue.Any progress with this? Had some local power outages overnight and had to use admin console to turn off the battery device write changes to get the pending writes to stop finally to my motion sensors.
November 9Nov 9 15 hours ago, sdynak said:Any progress with this? Had some local power outages overnight and had to use admin console to turn off the battery device write changes to get the pending writes to stop finally to my motion sensors.Has not yet been worked.
