October 3Oct 3 @apostolakisl Weird situation while using the pentair node server. I have created favorites on that allow me to turn on my pool lights and waterfalls within the UD Mobile app. I can turn those items on without an issue using the app, but their status does not update. i.e. If I turn on the lights the lights will turn on physically, but the app shows them as still off. Same thing will happen with my waterfalls.BUT...If I log into the Pentair app, not UD Mobile, and then check UD Mobile the status of these items automatically updates. It appears something is timing out with this nodeserver. Edited October 3Oct 3 by aca2b2
October 20Oct 20 @aca2b2 Are you using intellicenter or are you directly linked to the Pentair Color Sync Controller? I am testing with a direct connection as I don't have intellicenter. If you turn the lights on/off or whatever from IoX, it should update immediately. If you change it from the app or some other means, you need to wait for the polling interval, which defaults to 30 seconds.EDIT: I see from your other post you are using intellicenter and Globrite lights. I suspect the issue is that the plugin is designed and tested to work with Color Sync controller, both through Intellicenter and via direct link to Color Sync. The API is probably using the same commands as Color Sync commands, but not reporting back using the same format as Color Sync. I'm sure I can work it out and add that, but it would require you giving me your Intellicenter username and password. Edited October 20Oct 20 by apostolakisl
October 24Oct 24 Updated the plugin to now include native support of pentair globrite lights connected to intellicenter. Also updated intellichlor to be configurable from IoX on intellicenter pools that don't have intellichem automatically managing intellichlor. That is a lot of "intelli" to type.
