New Network Resources Page - Issues?
Checking out the new Network Resources page in UI. When I click on one, I get details about the Network Resource but not the actual content.
Am I missing something?
Screenshots comparing AC with UI for the same command:
All firmware and software fully up to date.
The invalid characters are likely because they are represented by the "2" and "3", however they are required per the Yamaha serial protocol used by my (much) older Yamaha receiver.
I also have a newer Yamaha receiver using POST. They too, do not display in UI. (Screenshots).
FWIW, all commands function properly in EISY and UD Mobile. I can also execute them successfully with the "test" button in AC.
Seems neither Test nor Export work in UI, resulting in an "API not found" error.
If I'm interpreting your question, no. Logged in via my local IP address.
As an aside, after a windows 11 update late this afternoon, I can no longer open the admin console.
Just noticed there is another update for EISY-UI since the one I performed early this morning, so I upgraded from 1.4.4 to 1.4.4_2.
I'm not sure, I can replicate the exact text and it shows in both AC and eisy-ui. There does a appear to be a small bug when refreshing the b with a resource open, which causes the body and Actual to not be populated. However Clicking the resource (to close details) then clicking again (to open details) fixes.
Edit: I think I found a race condition in populating the body. Likely why it is hard to replicate, submitted fix. ID: pull/113/changes
Screenshot 2026-10-17 at 5.20.09 AM.pngScreenshot 2026-10-17 at 5.15.21 AM.png
I can't seem to duplicate.
Tried running in Google Chrome and get the same result, ie. not displaying.
Also, Windows seems to have broken Java.
Re: API not found. If I click on the Zwave Protocol in the menu, I get "API not found" and the page hangs at the error pop-up. ie. clicking "OK" doesn't close the pop-up. Only way out is to refresh the browser. This happens in Chrome and Edge.
3 minutes ago, Javi said:
See my edit, race condition found.
With regards to AC, I'm not sure I don't have windows machine available. My guess is same old Java issues.
Admin console icon appears in the tray but I can't bring it up. Also can't close it other than using the task manager to "end task". Clicking on another jnlp file just creates another instance exhibiting the exact same behaviors. I tried fully uninstalling and reinstalling Java, but same result. For some reason, the download page on Java.com wouldn't work until I switched to Chrome. All of the Java issues occurred after yesterday's windows 11 update. I'm at a loss.
I'm glad you folks are moving away from Java. I can't see this getting any better as time goes on.
Re: race issue. Will wait for the pending fix.
Not related, but check an incognito page, browser might need a hard refresh (F5) to clear cache.
No other pages open as far as I can tell.
Nodes page no longer working either. ☹️
And if I click on PG3, it boots me out to the login page where I'm stuck in endless "successful" logins back to the login page.
Did you try a new incognito as suggested?
Good news! service restart did the trick. No further API errors that I can see.
Also, Network resources are displaying properly and the Test button is functioning again.
Thanks once again for your assistance!
