October 16Oct 16 Did something wrong. Tried to move the ring plugin from pg3 to the eisy-ui plugins. Ring plugin shows up in the eisy-plugins with its three nodes. Then went through the process in the eisy-ui to remove the plugin from PG3. Now the Ring plugin is not showing up in the node directory. For the other PG3 plugins moved to eisy-plugins but did not remove from PG3 they are working fine. Not sure what is going on ????
October 16Oct 16 Author Not sure if the latest update fixed this problem. After updating this afternoons Beta update, ring nodes have appeared in the node list. Tried a power reboot this morning to no effect.Thanks ?
