October 17Oct 17 Got production caught up to dynamic JSON profiles as well as fixing a Ratgo depreciated label issue.Let me know of any feedback. I have seen in other plugins (Tahoma) that with the jump to the JSON profile migrated plugins from the old PG3 to the new Eisy-ui needed an Eisy reboot to remove a profile error. When installed straight from Eisy-ui it seemed to be fine. YMMV.3.2.3 \ DONE VirtualGarage Ratgdo: ESPHome REST URLs use entity display names (e.g. /light/Light) instead of deprecated object_id paths; SSE state events accept new id format ahead of ESPHome 2026.7 3.2.2 \ DONE dynamic JSON profiles (Phase 1): updateJsonProfile instead of static profile/ zip for eisy-ui sync ; requires IoX 6.0.6+, PG3x 3.4.5+, udi_interface 3.4.5+; install.sh renames profile/ to profile.static on EISY; profile/ XML remains source for data/base_profile.json; bump profile_version in server.json when JSON base changes 3.2.1 \ DONE fix config overwrite: stop re-injecting example devfile and sample devices on every parameter loal DONE remove example customParams from server.json so Polyglot updates do not reset user configuration DONE clear "Waiting on valid configuration" notice when discovery fails
October 18Oct 18 I did the upgrade and it seems there is a problem according to the log file but it seems to me like things are still working. I don't know if this is because I'm still using the old config where I list them within PG3 instead of uploading a file to eisy.2026-10-17 20:25:05.756 Thread-761 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:08.757 Thread-762 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:11.758 Thread-763 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:14.545 Command udi_interface INFO VirtualSwitch:DOF_cmd: 1:switch 1, {'address': '1', 'cmd': 'DOF', 'query': {}}2026-10-17 20:25:14.545 Command udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot.2026-10-17 20:25:14.597 MQTT udi_interface.interface INFO interface:_message: Successfully set 1 :: ST to 0 UOM 252026-10-17 20:25:14.638 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata2026-10-17 20:25:14.761 Thread-765 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:17.764 Thread-766 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:20.764 Thread-767 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:22.770 Command udi_interface INFO VirtualSwitch:DON_cmd: 1:switch 1, {'address': '1', 'cmd': 'DON', 'query': {}}2026-10-17 20:25:22.770 Command udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot.2026-10-17 20:25:22.816 MQTT udi_interface.interface INFO interface:_message: Successfully set 1 :: ST to 1 UOM 252026-10-17 20:25:22.858 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata2026-10-17 20:25:23.794 Thread-769 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:26.767 Thread-770 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exiting2026-10-17 20:25:29.772 Thread-771 (poll) udi_interface ERROR Controller:poll: Node not ready yet, exitingI also tried migrating the plugin to eisy and the temperature nodes did not work so I migrated back to PG3
October 18Oct 18 There was a devfile on my configuration page and things seemed to clear up after deleting that. I worry about trying the migration again, maybe I will give it a try when I have more time. Thanks for all you do sjenkins!
November 11Nov 11 Author @tazman ,Wondering if the devfile was the example one which is pushed on a new install. Did it have example in the name? Just to be clear when you say migration are you talking upgrading to the latest version or migration to eisy-ui from pg3?
November 11Nov 11 @sjenkins yes it was the example one with the example in the names. I ended up doing the migration from PG3 to eisy-ui and had to rename everything but I guess that is the price of being the early adopters since it sounds like they fixed the naming resets in a later release.
November 11Nov 11 Author Interesting, I migrated really early and had all my 20 or so plugins came along. Didn’t have the issue where the example got reactivated either. Wonder if you were one of the lucky ones who did it in a version with some issues; I certainly read about them & wondered why mine went so slick. It’s not as if I did anything beyond hitting the button. So you know I have been running this plugin in the new environment since then so all should be ok once over.
