October 23Oct 23 @bmercier Two issues:1) Whenever I reboot after an upgrade, Holiday and SUN plugins are Disconnected as shown below under the NODE tree2) However, under Plugins, they will show as Connected, see below. A Restart of the plugin quickly fixes the problem and both will show connected.
October 23Oct 23 I was seeing similar inconsistencies. It seems the latest eisy-ui updaate 1.4.6 may have corrected that for me.Rob
October 23Oct 23 Author 1 hour ago, RRalston said:I was seeing similar inconsistencies. It seems the latest eisy-ui updaate 1.4.6 may have corrected that for me.Robit did not fix it for me.. I am on all the latest versions from the Staging Repo.
October 24Oct 24 23 hours ago, dbwarner5 said:@bmercier Two issues:1) Whenever I reboot after an upgrade, Holiday and SUN plugins are Disconnected as shown below under the NODE tree2) However, under Plugins, they will show as Connected, see below. A Restart of the plugin quickly fixes the problem and both will show connected.That could happen if eisy-ui and plugins are started before IoX is ready. eisy-ui would have received the status, and tried to update the property on the IoX node, but would fail if IoX is still initializing.Will check what I can do about this.
October 24Oct 24 Author 34 minutes ago, bmercier said:That could happen if eisy-ui and plugins are started before IoX is ready. eisy-ui would have received the status, and tried to update the property on the IoX node, but would fail if IoX is still initializing.Will check what I can do about this.this is only happening to SUN and HOLIDAY plugins.
