1 hour ago1 hr I have been trying to update packages so that I can start using the new eisy-ui. Here is the message I get when starting the process. However, the system comes back right away and says packages are up to date but no eisy-ui. When I try again, I get the same message.
42 minutes ago42 min If your FreeBSD OS is below 13.2p11 (check via https://eisy.local:8443/WEB/sysconfig.txt), do not attempt this upgrade; it will brick your system. Instead:Back up your IoX and PG3Reflash your eisy using our USB reflash stick
