November 3Nov 3 Running 1.8.65 and my Temp, Humidity sensor is showing up normally as a node in easy ui. Opening the node shows all the fields correctly (notably, temp is in fahrenheit). However, when the node is used in programming, to set the value of a state variable to the temp of the sensor, the only temp option is centigrade. Have re-installed, rebooted with no change. Any ideas?
November 3Nov 3 Got it - I think I found the issue - eisy does not read the node definitions the same way - the program goes for the initialized value - not the current valueWorking on a fixCan you help test once I believe it is working - I can release a beta version Edited November 3Nov 3 by Panda88
November 4Nov 4 I put 1.8.66 in the non-production store - give it a try - if is does not work, can you describe how you test it (so I can do the same)If you need the local version, let me know - you should be able to install on top of your existing one (and revert back if needed) Mine has been running for half a day without issues
November 4Nov 4 you should be able to install on top of your existing one - and see if it fixes the issue - or is there no beta store with the new system Maybe migrate back - install beta in PG3 and test - if OK, I'll release production and you can install that and migrate back
November 4Nov 4 Author So I loaded the new plugin version in PG3 (AC side) and configured. Re-started the new version, then rebooted the AC and voila. It works. The beta version shows up as node 5 in the pics. Thanks!!
