Tuesday at 11:51 PM5 days I'm having trouble integrating my ratgdo32 with eisy using the ratgdo plugin. I'm using Security+ 2.0 with ESPHome firmware 2026.9.1. The plugin shows connected, but no nodes appear. When I click Discover, I receive this error:"There was an error attempting to connect to the device at [local IP address]. Please check the log files and correct the issue before restarting the plugin."I can access and control the garage door through the ratgdo web interface using its local IP, but the /text_sensor/firmware_version endpoint doesn't work. I've tried configuring the plugin with and without http://, with no success.Has anyone found a solution? Could this be a compatibility issue with the newer ESPHome firmware?
