November 4Nov 4 I am using the new web interface with the latest updates to everything.I have a scene with a Z-Wave thermostat (amongst other nodes). The thermostat shows up correctly as "DR Thermostat" an alias for ZW003_1, but there is another Z-Wave device in the scene: ZW010_1 that doesn't match any of my actual devices. If I click on the node in the responders list for the scene, I get a Responder Link dialog showing the scene name and the (bad) responder name of ZW010_1. There is an error message that says:Error: Responder node with address ZW010_1 not found.There seems to be no way to delete the zombie node from the scene. This node does not appear in the list of responder nodes for this scene.I ended up deleting the entire scene and that seemed to fix it. There should be a more surgical way to delete nodes from a scene, whether it exists or not.
