Thursday at 04:39 PM3 days I'm getting an error after migrating the Rachio plugin:ERROR: 11/05/2026 10:32:50 See log for: Connectivity test to my.isy.io:443 was not successful. Sending: POST to my.isy.io:443 /api/eisy/pg3/webhook/response/(redacted)/4 headers={'Content-Type': 'application/json'} data={"test": 0.3952693794183477} Received: status=408 reason=Request TimeoutPlease confirm portal webhooks are enabled, See Webooks RequirementsERROR: 11/05/2026 10:32:50 See log for: Unable to discover until webooks are working properlyWhen I read about enabling PG3 remote access via the link, the info. is a bit dated, but under my.isy.io I see the following under select tool->PG3->remote connection, anyone else see this problem or have a solution?Remote connection feature available:YesRemote connection configured:YesRemote connection active:Yes Edited Thursday at 05:51 PM3 days by JTsao
Thursday at 05:20 PM3 days I made sure PG3 remote access was available, configured, and active in portal. I reconfigured PG3 remote access and rebooted Eisy. Restarted Rachio with same error. In logs webhook test still failed despite general portal connectivity.
Thursday at 05:34 PM3 days 19 minutes ago, drprm1 said:Having kind of same issue but mine returns 503 error than 408I see you have Ring.Can you test Ring connectivity? This uses webhook too.
Thursday at 06:37 PM3 days 1 hour ago, bmercier said:I see you have Ring.Can you test Ring connectivity? This uses webhook too.No incoming event seen when recording was confirmed via Ring app
Thursday at 11:22 PM3 days Author The Rachio node server did NOT refill my pool today (under eisy program control - via a sprinkler zone) so I guess I have to move it back to PG3 to work for now...
Friday at 07:38 PM2 days On 11/5/2026 at 2:37 PM, drprm1 said:No incoming event seen when recording was confirmed via Ring appPlease test Ring using the Controller node. It has a test button, and a property that will tell you if PG3 remote access is successful.FYI, looking at the Rachio error, I see the call to the webhook url returned a 503. This tells me that you unit might not have been online on portal.
Saturday at 02:47 AM1 day Looks like Ring received actual motion webhooks but Rachio failed Rachio-log-2026-11-07T02-45-27.034Z.zip
Saturday at 01:09 PM1 day Author iAqualink node server doesn't appear to work after migrating to eisy-ui plugin either...
