EP10 and KP125 plugs not found
I have a number of EP10 and KP125 smart plugs that for some time now no longer show up in the plugin's (3.3.27) node list. My KP125M plugs are identified and working correctly. The EP10s are running 1.1.2 firmware and the KP125s are running 1.0.14. EISY is running version 5.8.4. All of the smart plugs are controllable by the KASA app.
The network is a EERO mesh and was running everything well before these plugs dropped off a couple of months back. These unidentified plugs are all on the same subnet with other identified KASA devices. During discovery, the EP10s are reporting "device rejected login".
On another post, there was a mention of the firmware update on the EP10 knocking it off of the node list and to open KASA up for third party applications. That has been enabled from the beginning with KASA.
Most recently I tried a factory reset on an EP10 plug and a re-install but that was not successful in getting the plug identified in the Polyglot.
Other than my current work around, which is automation through the KASA app, does anyone have something else that I can try? I would really like everything to be controlled by the EISY.
Thank you, RK
