27 minutes ago27 min I have two plugins on my Polisy installed from the eisy ui plugin section (not pg3x). These are two that I created and installed them from the developer section of eisyui, (where you set purchase options). On my eisy, when I push an update to git hub and update the store version, the plugin then reports that an update is available. But on the Polisy there is no mention of an available update. I had to click on re-install which did then install the latest version. The Polisy is running the current up to date production version of all the packages. Basically, it looks like the Polisy with the currently up to date production packages isn't doing version checks on plugins.
