Variable data editing in eisy-ui node screens
We're all used to how node controls are laid out in Admin Console: status information at the top, editable values in the middle, and action-only buttons at the bottom. The editable values area was particularly handy, because you could see the current value of that setting in the edit box,. You could edit it, and then click on the button/label next to it to make an immediate change to that value. That capability appears to have been lost in eisy-ui. Now you can only view the current value at the top (like a status), and then need to locate a separate list box to change that value (where you can't see the current value). When the list is long, you have to scroll back and forth to make and then see the change. Not great. Even Claude (in eisy-ai) says it like this: "In eisyUI the property tiles at the top are read-only displays. The editing happens through each variable's command input, in the list at the bottom."
I'm working on a plugin in eisy-ai that allows editing 128 variables in a connected controller, so that's a long list. Initially I had it set up with a list box to "set" the variable I wanted to change, and then a second box to choose the value to set it to. It worked, but changing a value in a program required two separate program lines, not good.
Seems we've lost something that was clean here.
