Thursday at 10:30 PM3 days Hi @Jimbo.Automates, After a power outage killed my M1XEP, I replaced it with the new ELK-M1XIP (the M1XEP replacement ELK released in Sept 2026). Everything connects, but the ELK plugin keeps dropping the connection and reconnecting, and it gets worse over the day.Setup:- Polisy, IoX 6.1.2_10, eisy-ui 1.4.8 (plugins integrated in eisy-ui)- ELK plugin 3.10.16, slot 1- M1XIP on firmware 3.0.4 (latest)- Homebridge (homebridge-elkm1) and Home Assistant also connect to the M1XIP on 2101What I'm seeing:- 77 disconnects today. Overnight they were every 8 to 60 minutes; by late afternoon they were every 2 to 10 minutes. Each one is either: elkm1_lib.connection WARNING connection:_heartbeat_timeout: ElkM1 connection heartbeat timed out, disconnecting or elkm1_lib.connection ERROR connection:connection_lost: Connection reset by peer- Often preceded by: Controller:timeout: ELK Controller: Timeout sending message SD!!! (also UA and KA)- The plugin reconnects within seconds and logs "All nodes added, ready to go..."- Over the same period, Homebridge held a single connection to the M1XIP with no drops at all, so the card and network look fine.Unknown message on every reconnect: Controller:unknown: ELK Controller: Unknown message ti: ST000000-XK305717317112601000The M1XIP seems to send the XK heartbeat with an "ST000000-" prefix, so I wonder if some XK heartbeats aren't being recognized, which could trigger the heartbeat timeouts.Wondering if there's a possible fix?Thanks!Ryan
