Ecobee on PG3x - vacation status
I have ecobee stat via HomeKitHub working now.
How do I get Vacation status from the ecobee stat?
I have monitored the Smart7 climate status and it doesn't change.
However I did find the Smart1 Climate status changing and modified the configuration of smart2 to say "Vacation". It does report through in IoX and eisy-ui with that nomenclature.
However, it will not trigger a program and does not come through without Querying the stat status.
Smart7 node is labeled "Vacation" by default installation but would never function.
Is there something I am missing here, or is getting Vacation status possible and coded for yet?
smart2 mentioned in error
It appears that vacation mode shows up in Climate Type as Smart1 and it's changes will not trigger through HomeKitHub.
Changing the mode from Heat to Off or back triggers an update in the Vacation status though.
Was this an intended style of operation or is this a bug to be fixed yet? (PG3x)
