Sunday at 02:52 PM2 days When I try to set hte XY setting for a bulb in a scene, it appears to be fine until I click on Update Link. Then the value loses its decimal placing and becomes a whole integer. The net result is the hue bulb then ignores the change when the scene is activated. The XY setting works fine on the bulb directly, just no in the Scene. Am on 0.1.11 of the Hue plugin and all the latest versions in the Staging Repo. See screen shots below. Thanks.Setting screen in SCENE: Result after hitting Update Link:
Monday at 06:15 PM1 day Solution On 11/22/2026 at 7:52 AM, dbwarner5 said:When I try to set hte XY setting for a bulb in a scene, it appears to be fine until I click on Update Link. Then the value loses its decimal placing and becomes a whole integer. The net result is the hue bulb then ignores the change when the scene is activated.The XY setting works fine on the bulb directly, just no in the Scene.Am on 0.1.11 of the Hue plugin and all the latest versions in the Staging Repo.See screen shots below. Thanks.Setting screen in SCENE:Result after hitting Update Link:Thanks.Fixed saving scene links with prec values. Did not make it into the next release, so likely subsequent. Until then please use Admin Console for this situation.fix ID: /eisy-ui/pull/175
