November 23Nov 23 Has anyone gotten the device mentioned in the subject/title to work with the eisy homekithub plugin (after migration to eisy-plugin)?
November 24Nov 24 Author I'll answer my own question - after moving the thermostat off my IoT VLAN and back to my main LAN, I got it to pair. I changed "Create generic IoX control nodes (Professional)" to true, and now I can see the current temperature and heat set point along with other settings that don't apply.
Tuesday at 03:29 PM5 days 14 hours ago, JTsao said:I'll answer my own question - after moving the thermostat off my IoT VLAN and back to my main LAN, I got it to pair. I changed "Create generic IoX control nodes (Professional)" to true, and now I can see the current temperature and heat set point along with other settings that don't apply.@JTsao , did you do something to put the Schluter in pairing mode in order for it to be discovered? Mine is not being seen when I do a discover using HomeKitHub.
Tuesday at 04:38 PM5 days Author I think if you remove and then restore the front panel (turn the screw at the bottom to open) that it may put it in pairing mode. The pairing code is on a sticker on the top center of the circuit board, along with a scan code.Homekit did detect the thermostat 1X on my IoT VLAN (possibly only the 1st time after I removed/replaced the front panel), but subsequent attempts on the IoT VLAN did not work - so I moved the thermostat back to the main LAN, removed and replaced the front panel to reboot/get new IP address and then homekit was able to detect it.
Tuesday at 05:03 PM5 days 24 minutes ago, JTsao said:I think if you remove and then restore the front panel (turn the screw at the bottom to open) that it may put it in pairing mode. The pairing code is on a sticker on the top center of the circuit board, along with a scan code.Homekit did detect the thermostat 1X on my IoT VLAN (possibly only the 1st time after I removed/replaced the front panel), but subsequent attempts on the IoT VLAN did not work - so I moved the thermostat back to the main LAN, removed and replaced the front panel to reboot/get new IP address and then homekit was able to detect it.Thanks, removing the cover, and then replacing, put the tstat in pairing mode for me as well. I don't find this documented any where, so thanks again.
