Monday at 06:38 PM1 day Is the Z Matter enclosure needed to move my Z Wave card from my Polisy ?Is the wifi antenna needed for my EISY ?Do I need anything other than the serial to usb adapter for my PLM ?Will I need anything else for my migration other than that I have mentioned above?Thank You,
Monday at 07:01 PM1 day Yes. The easiest way is to get the enclosure from UDI if it's available. An alternative is to make your own, like I did (below).If you have a Polisy Pro with a ZMatter board, then you'll have 4 antennas. Only the antennas connected to the ZMatter board (Z-Wave and Zigbee) antennas need to be kept with the ZMatter board. The eisy has built-in wifi so no extra antenna needed.The serial adapter is all you need if you have a sreial PLM.
