Thursday at 08:22 PM1 day I updated to OS 14.5, IoX 6.1.2_18, UDX 5.5.0, and eisy-ui 1.4.13 and waited to be asked to reboot. After reboot I could no longer access any of my Z-Wave and the protocol menu in eisy-ui said that the Z-Wave Radio was not connected. I eventually rebooted the eisy again and that did not fix it. About 20m after reboot, without any interaction the z-Wave radio came back and everything worked again just fine. I am just throwing this out there because it is not something I have ever experienced before...
Thursday at 08:39 PM1 day I've seen that happen too. And yes, it fixes itself after some time. I wanted to create a startup program that querys the devices but you really need to let it take it's time to recover.
8 hours ago8 hr Had this happen to me yesterday morning. Was still not working this morning. A reboot corrected it this morning
2 hours ago2 hr I am running 2 eisy's (one is original version and other is r2) and had this occur on both after the update. The r2 finally came back up on its own but the other one indicated "zwave radio not connected" so unplugged everything and plugged back in with the radio now showing as connected now but none of the zwave devices would work. I waited quite a long time to see if would rebuild but never did. It ended up requiring 2 more reboots to finally get the zwave working again. I hope that it was just a matter of following the update and not something that run into if ever reboot or lose power moving forward.
33 minutes ago33 min I think I'm in the middle of exactly this. I updated to the current versions and everything seemed to work then I went through the exercise of removing a zwave switch from the mesh and bringing it back in as LR device, and again things seemed to be working. However, soon after that all my zwave stuff stopped working. I've rebooted a couple of times, no joy so far.
