6 Button 2486 switch - dim buttons
I'm trying to figure out if there is a way to dim the large On and Off buttons on the 2486 - 6 button switch. I can dim all the buttons using LED Brightness, but I can't seem to dim or cut off only the On and Off buttons. Even if I put button 6 in a scene, it doesn't seem to be isolated to 6, it effects 6a, 6b, 6c, 6d. Also, is there any way to make these brighter so they can be seen in daylight? It appears in some documentation for other devices that there are 32 levels of brightness, but isy 99 seems to only allow 16 levels for on and 7 for off. It also appears that you can't adjust them so that on and off look the same brightness - this would help if you just wanted back lighting and no difference for on and off. It also appears that using 0,0 led brightness you still get a dull light when on.
Using 'LED Brightness' effects all the leds of the switch. There is no way to control an individual button's led brightness.
There is no way currently to adjust them so that on and off look the same brightness.
0,0 does indeed give you a dull light when on. This is the darkest you can get.
See this post for turning off the "Off" buttons backlight on a 6 button KPL:
http://forum.universal-devices.com/view ... 9743#19743
I have a program that turns all the switch backlights way down at night and back to full brightness the next morning so I can tell what is on in full daylight. (actually it is a series of interrelated programs that controls this function, not just one)
