Why does a PLM need to be restored?
My system has been relatively static for a while. Tonight I went to turn out some lights that are in two different locations which I have been doing nearly every night since the time change and thought, why don't I just make fast off on the first switch turn off the others for me?
So I wrote the worlds simplest program on the ISY (well, perhaps there are simpler ones, but...), and it didn't work! It was driving me crazy for a while, going back and forth testing, checking the program, etc. I finally remembered to run the event view and couldn't see anything at all. Searching the forum I came across the advice to restore the plm. Sure enough this worked.
Why does the PLM need to be restored from time to time?
Why can't the ISY check to see if the PLM has lost it's mind and restore it on it's own? Or if not that, why not just restore the plm on a schedule automatically?
-Tome
Hi Tome,
The answer is: it should NOT!
This is usually a symptom of a failing PLM and I strongly recommend getting it replaced.
Michel,
If I call Smarthome and tell them it lost it's mind but is better now - sounds like some people I know :lol: - will they replace it for that reason?
Tome
