jkraus Posted November 30, 2010 Posted November 30, 2010 I ordered a new DB PLM over the weekend when I thought my old one (non-DB) was biting the dust. It turned out that it was not my PLM going bad but rather an EZX10 (Thnaks you Michel for helping me out). In any case since I now have the new PLM what are the advantages? I think I read they are faster, but any other benefits or downsides (besides separate power supply)? For new install I think I have the sequence correct: - power off ISY -exchange PLMs -power up ISY - restore PLM - restore devices Correct?
Brian H Posted November 30, 2010 Posted November 30, 2010 That is the way I did it. Except -Restore devices. Restore Modem (PLM) puts the new PLM ID in all the devices as part of the Restore Modem function. Even warns to put RF devices in the linking mode.
jkraus Posted November 30, 2010 Author Posted November 30, 2010 OK, but a restore PLM takes quite a while, do your Remote Lincs and MS time out first? I think so. So I assume that you can then individually restore them after the PLM restore?
Sub-Routine Posted November 30, 2010 Posted November 30, 2010 Hi Joe, The battery devices should be written to first. If any have the green arrow pointing at them after Restore Modem then you will want to Write Updates to Device. OK, but a restore PLM takes quite a while, do your Remote Lincs and MS time out first? I think so. So I assume that you can then individually restore them after the PLM restore?
