Motion Sensor/Lights program
I have a motion sensor in my entry area. The way I want it to work is:
1) If it is evening and no one has turned on the entry light, motion in the area should cause lights to come on. After a timeout period, they should go off on their own.
2) If someone turns on the lights manually (controlled by a SL), they should stay on unless turned off at the switch.
3) Additionally, if the motion sensor turned them on, but someone then turns the switch on as well (before the motion program turns them off), they should stay on until turned off at the switch. This is just a special case of #2 - using the SL to signal I want them left on.
The problem I have with what I currently have programmed is that if I turn them on at the switch and someone (or some dog :-) trips the motion sensor, the lights will go out after the timeout period.
My program(s) that control this now are as follows. What/where can I add something that will leave the lights on if turned on from the switch?
Folder "Entry Light Control"
EntryLightControlStatus
EntryLightsOff
EntryLightsOn
EntryMotion
EntryOccupied
Folder "Time Variables"
Evening
From Sunrise
To Sunset (same day)
And (
Status 'EntryLightsEast' is On
Or Status 'EntryLightsWest' is On
-No Actions - (To add one, press 'Action')
EntryLightsOff
Program 'EntryOccupied' is False
AND Program 'Evening' is True
Set Scene 'FrontPorchControl' Off
EntryLightsOn
Program 'EntryOccupied' is True
Set Scene 'FrontPorchControl' On
EntryMotion
Status 'EntryMotion-Sensor' is On
EntryOccupied
Program 'EntryMotion' is True
Or From Last Run Time for 'EntryMotion'
For 0 seconds
Evening
From Sunset
To Sunrise (next day)
Hello,
My suggestion would be:
  Control 'Entry Light Switch' is Switched On
  Disable [all programs that automatically turn the lights off]
and then one to re-enable them again:
  Control 'Entry Light Switch' is Switched off
  Enable [all the programs you disabled above]
This is what I use for my garage lights (same applications) and it works great.
- Brian
Hello,
...code deleted....
- Brian
Thanks Brian,
That might have done it. I now have:
DisableAutomaticControl
   Control 'EntryLightsEast' is switched On
 OR Control ''EntryLightsWest' is switched On
    Disable Program 'EntryLightsOff'
and
EnableAutomaticControl
    Control 'EntryLightsEast' is switched Off
 OR Control ''EntryLightsWest' is switched Off
     Enable Program 'EntryLightsOff'
That is quite the complicated web of programs there. It seems overly so, to me. What is the EntryLightControlStatus used for? This is your folder condition? Which programs are in this folder?
You appear to have two entry lights (east and west). Do you want to disable the motion program if a SPECIFIC (east? west?) one is on, EITHER are on, or only if BOTH are on?
If one light is on manually, how do you want this to affect motion control of the other?
If both lights are on as a result of motion, and you manually activate only one switch, how do you want this to affect the automatic off of the second switch? If both lights are to remain on, are you willing to manually turn off two switches or do you want a single switch control of both lights?
What devices are in your "frontporchcontrol" scene and which of these are controllers?
Writing without fully understanding your requirements, why not take advantage of the oft-maligned feature that stops programs from executing when there is a change in entry conditions:
Program 1
if
time from sunset to sunrise (next day)
And Status 'EntryLightsEast' is not On
And Status 'EntryLightsWest' is not On
then
Wait timeout period
Set Scene 'frontPorchControl' off
else
This program would not execute if either a) during the day or B) if EITHER of the entry lights are on. Furthermore, if (after the scene is turned on and during the wait period) EITHER of the entry lights are turned on manually, the execution will stop and BOTH lights will remain on until both are turned off manually.
The problem I foresee with this is the potential that sunrise occurs during a wait period. If so, the lights will remain on. To counter this possibility, I would add a second program:
if
time is sunrise
then
What am I missing?
The folder is called "Entry Light Control" and everything is in there except "Evening" which is in the Time Variables folder. I have them listed this way in my original message. EntryLightControlStatus appears to be doing nothing. Not sure why I had that. It has been a while since I have looked at this...
East, West, and a Keypad are all in a Scene (FrontPorchControl) together as controllers. Turning on/off one, turns on/off the others. They are just multiple locations for turning on the same set of lights. I think this answers the next three questions.
So skipping ahead...
Program 1
if
then
Wait timeout period
else
if
time is sunrise
then
What am I missing?
I think you are missing the motion sensor entirely. I am all for simplification, less is more! I will think about it some more. I recall trying to do it simply the first time and it didn't work well at all, and hence the various programs as variables approach.
-Tome
How 'bout Program1:
       Control 'EntryMotion-Sensor' is switched On
   And Status 'EntryLights' is Off
   And From Sunset
       Run Program 'Program2' (Then Branch)
       - Nothing -
and Program2:
       Control 'EntryLightsSwitch' is switched On
   And Control 'EntryLightsSwitch' is not switched On
       Wait 3 mintues
       - Nothing -
Indeed! I would add this to my first program.
if
And Control Motion Sensor switched on <<<<<<then
Wait timeout period
else
But I like kingwr solution just as well.
