Newby Program Question
Been working on getting my ISY99 going. It's been pretty painless. I would like to have a program so I use a button on my KPL switch when I am gone. Then one of my lights in the house would go on and off. It would come on at Sunset and then off at different times in the evening. I wrote a program but I;n mot sure my logic is good. I would copy the program and show it by I can't get into the ISY from my Mac.
Can somebody give me an example program so I know I have it written correctly?
Sounds like you need a PC. Those darn Macs aren't much good for anything!
Why do you suspect your logic is no good? Is your program not working?
How about the following:
if
       status KPL button is on
  and
       From    Sunset
       To      10:00:00PM (same day)
       Set 'one of my lights' On
       Wait  30 minutes  (Random)
       Set 'one of my lights' Off
There are several ways to do this. The example above may suffer a shortcoming that you may or may not care about. If you turn the KPL button off with the light on, the program will cease and not turn it off automatically. Try things out. You may find that you have preferences in how you do things.
Enjoy!
I wasn't sure if I had my and or's correct for multiple days. Here is what I have (although I have every day listed):
If Status KPL Button is On
And On Sat
From Sunset + 20 minutes
To 10:30pm (same day)
Or On Sun
From Sunset + 36 minutes
To 10:43pm (same day)
Or On Mon
From Sunset + 16 minutes
To 10:25pm (same day)
Or On Tue
From Sunset + 5 minutes
To 10:49pm (same day)
Set 'Kitchen Pendants' 70%
Set 'Kitchen Pendants' Off
Are my and/or's correct or would I need parenthesis?
You need parens to AND the first If condition with all the others
And (
On Sat
Or On Sun
Or On Mon
Or On Tue
Thanks Lee
Just chiming in. I think we all use something similar. Here are some more examples:
This is my main security night time program that simulates people moving about the house:
       From    Sunset  + 15 minutes
       To      11:50:00PM (same day)
   And Status  'Living Room / Living Room Fan / Away - KPL- A' is On
       Wait  1 hour  (Random)
       Repeat 8 times
          Send X10 'H1/On (3)'
          Wait  20 minutes  (Random)
          Send X10 'H1/Off (11)'
          Wait  5 seconds
          Send X10 'H5/On (3)'
          Wait  10 minutes  (Random)
          Send X10 'H5/Off (11)'
This one also runs in parallel to simulate someone going into our guest bedroom to get something:
       From    Sunset  +  3 hours
       To      11:00:00PM (same day)
       Set 'Bedroom #2 / BR2 Table Lamp' Fast On
       Wait  1 minute  (Random)
       Set 'Bedroom #2 / BR2 Table Lamp' Fast Off
       Wait  45 minutes  (Random)
       Wait  2 minutes  (Random)
This one simulates me feeding the livestock and runs in parallel with the two programs above:
       On Mon, Tue, Wed, Thu, Fri
       From    Sunset
       Wait  15 minutes
       Wait  2 hours  (Random)
       Set 'Shed / Barn Lights' On
       Wait  12 minutes
       Set 'Shed / Barn Lights' Off
This are my favorite two programs:
   And From    Sunset  +  1 hour  and 15 minutes
       For      2 seconds
       Wait  10 seconds (Random)
       Run Program 'Flood Flasher' (Then Path)
The program above runs a flood light flasher program only 20% of the time. The flasher program (below) turns all of my outside floodlights on for a brief period as if we were home and were looking outside at something or we hit the wrong light switch.
       Set 'Outside House / Flood Light Override' On
       Wait  15 seconds (Random)
       Set 'Outside House / Flood Light Override' Off
and FINALLY, a program to turn off the mess when I come home and switch off the away button called "home" it also gives some audible feedback when away is set and chirps the KPL every 30 minutes as a reminder to turn it off when I am at home. This way nothing stays on if I switch off the away button when one of its branch programs, which immediately terminate, have a light turned on.
       Set 'Living Room / Living Room Fan' 1 (Beep Duration)
       Repeat Every  30 minutes
       Run Program 'Off ice Server Lights' (Else Path)
       Run Program 'Foyer Lights' (Else Path)
       Set 'Bedroom #2 / BR2 Table Lamp' Off
That is some nice code examples, art!
I like that shrewd move to step around the lack of a random number generator in the program.
* Orest
Thanks for the examples. Lots of good stuff there. I might have to do something like that next time I am at the house. I still have some more switches to add so I can do things like that.
Is there a way to make the time the program runs have a random start and end time? I kind of do that by using lots of "OR"s but would rather just have the ISY do it.
Random Timer Trigger:
       On Mon, Wed, Fri
       Time is Sunset
       Run Program 'Random Timer' (Then Path)
And Random Timer:
       Set Scene 'Living Room Scene' On
       Wait  2 hours
       Set Scene 'Living Room Scene' Off
Notice how you can combine Wait statements, first with a set wait followed by a random wait. In this case, the scene always stays on for a random period between 2 and 3 hours.
Any reason why you have it as 2 programs and not all in 1?
When an ISY program hits a Wait or Repeat statement, it will normally abort the program without completing if the trigger conditions become false. This housekeeping both gives the user a way to stop a program in its tracks and avoids the ISY running duplicate instances of the same program if the trigger action occurs multiple times. (An example of this might be a bathroom light timer--you wouldn't want the light to turn out if someone is still moving around in the room when a timer expires, nor would you want the light to turn out if someone went in, activated the timer, left the room, then someone else went in and just turned the light on as the first timer was about to expire.)
In your case, however, this logic presents a challenge. If you trigger the program with a time, then the program hits a wait statement, the time will be different so the program would abort. By splitting the program in two, there's no wait in the first program and the second program has no conditions that will cause it to abort while waiting.
But, I thought that the time condition, in this case, would only evaluate once per day (at sunset). I see no other trigger condition forcing an evaluation that could result in a false condition, halting the program. (You are not suggesting that the "wait" statement, itself, triggers an evaluation, are you?) I expect this program to be "true" indefinitely...and that a single program would work here.
But, I thought that the time condition, in this case, would only evaluate once per day (at sunset). I see no other trigger condition forcing an evaluation that could result in a false condition, halting the program. I expect this program to be "true" indefinitely...and that a single program would work here.
You may be right in the case of sunrise/sunset, I haven't spent the time testing it. I do know my way works.
Yes, of that I am sure.
For what it is worth, in support of another thread I ran a quick experiment with the following program:
Control 'Basement/Garage / SW GRS Garage Exterior Sconse' is not switched On
And Time is 7:44:00PM
At 7:44, the status of this program changed from false to true. It remained so until I switched the sconse on, at which point it went false. This tends to support the theory that time-based conditions themselves only trigger an evaluation at the specified time. This is consistent with my understanding and tends to support the GregE's apparent suspicion that this particular example can be accomplished as a single program. It sounds as if GregE has the same personality as me....deriving some irrational pleasure in minimizing lines of code.
I think, however, it may be good general practice to break them into two programs, just in case of something we were not smart enough to foresee. That is, unless we specifically want to take advantage of the ISY ability to halt programs midstream (such as certain motion sensor programs).
oberkc, that probably comes from my RPG programming. I can go with the 2 programs though just to make sure.
Instead of it running for between 2 to 3 hours using the wait, is there a way to do another random timer trigger to end the program. Something like this?
       On Mon, Wed, Fri
       Time is 10:30:00PM
       And Status KPL Button is On
       Run Program 'Random Timer 2' (Then Path)
and
If    - No Conditions - (To add one, press 'Schedule' or 'Condition')
       Wait  15 minutes  (Random)
The original program you wrote would, of course, be modified to only turn the lights on. I'm not at the house with the equipment or I would try it.
Sure, if you aren't interested in a minimum time, you can use just one Wait Random.
If you are asking whether lights can be turned on with one program and off with a second, I believe the answer is a confident "YES".
