oskrypuch Posted January 19, 2011 Posted January 19, 2011 Just wondering if Canadian locations are supported in the Weatherbug setup? Brantford, Ontario N3T 1R6 * Orest
rlav Posted January 19, 2011 Posted January 19, 2011 Yes it works from Canada, but with some limitation. I am locate in Montreal area. Here are the fields that I get. Those at 0 are not available. Temperature -7 °C Temperature High -4 °C Temperature Low -7 °C Feels Like -15 °C Temperature Rate 0 °C Humidity 73 % Humidity Rate 0 %/h Pressure 1011.18 Pa Pressure Rate 0 Pa/h Dew Point -11 °C Wind Speed 23 km/h Wind Average Speed 23 km/h Wind Direction NNE Wind Average Direction NNE Gust Speed 40 km/h Gust Direction NNE Rain Today 0 mm Light 0 %/h Light Rate 0 %/h Rain Rate 0 mm/h Max Rain Rate 0 mm/h R. Lavoie
Walrus Posted January 21, 2011 Posted January 21, 2011 No rain today data for Canada? Or is that just because you hadn't received any?
rlav Posted January 21, 2011 Posted January 21, 2011 Rain Today is one of the field that is not working. Beside it is pretty cold today and we had some snow. All the fields with Rate, Light, and Rain do not work. R. Lavoie
