program active test
Is there a way to directly test in an IF statement if another program is active/idle, other than setting/resetting another program as a variable to show the state?
* Orest
I think you can just right click the program and choose run if. I think that will do what you are asking
I don't believe so, but it is possible that I misunderstand your question.
From the Program Summary page, programs can be listed as Enabled (on/off), Activity (idle/running 'xxx') and Status (true/false)
In an IF statement you can test for the Status like so:
   Program 'DoSomething' is True
I don't see any way to directly test for the Activity of a program, IOW whether it is currently idle or running Then or Else, etc.
You could handle it with a separate Program "variable", but that is a bit clumsy.
That was what I was asking.
* Orest
Well, that is more or less using a program as a variable, but yes it is a little more elegant.
Like so ...
Program DoSomething
do stuff
do stuff
Run Program 'DoSomething' (else)
* Orest
I could fine a use for such a feature.... maybe you would want to repost in the "Product Requests" or GUI Enhancements.
