time interval event programming
OK, I have event1, event2 and actionA.
If event1 occurs, then if within 20 seconds event2 occurs, then do actionA.
How do I code that in ISY?
* Orest
OK, figured out a way to do it ...
program var entry sense.wait (a variable)
program entry sense
       Program 'var garage open' is True
   And Program 'var dark' is True
   And Program 'var sleeptime' is False
       Run Program 'var entry sense.wait' (Then Path)
       Wait  20 seconds
       Run Program 'var entry sense.wait' (Else Path)
program entry sense.do
       Control 'laundry rm / LND - PIR-Sensor' is switched On
   And Program 'var entry sense.wait' is True
       Set 'front hallway / FH - Pots' 80%
       Set 'kitchen / KIT - Pot' On
