January 27, 201115 yr Ok, I'm stumped and need some suggestions. I have a switchlinc in my master bedroom that is acting as a controller to a collection of other lights this was originally the desired behaviour. I added a (seperate) keypadlink so I decided to repurpose this switch to just control two table lamps. The problem is, I can not seem to get it to 'forget' the scene. The scene has been deleted in ISY (its a 99i). If I factory reset the switch it does not control any of the other devices, but as soon as I restore the device in ISY (which shows it not currently lnked to anything) it starts controlling the lights again. I factory reset one of the switchlinc's it is controlling. It also stopped acting like a member of this scene, but as soon as I restore the device in ISY (so it's in it's normal scene's) it starts responding to the above switch again. I'm stumped, ISY shows no obvious links and factory reset it clearly doing something until ISY reprogramms the switch. What have I forgotten or missed? Thanks, Bill
January 27, 201115 yr Author Wed 01/26/2011 05:56:33 PM : [iNST-SRX ] 02 50 08.50.E9 00.00.01 C7 11 00 LTONRR (00) Wed 01/26/2011 05:56:33 PM : [standard-Group][08.50.E9-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:56:33 PM : [ 8 50 E9 1] DON 0 Wed 01/26/2011 05:56:33 PM : [ 8 50 E9 1] ST 255 Wed 01/26/2011 05:56:33 PM : [iNST-SRX ] 02 50 08.50.E9 13.22.DC 41 11 01 LTONRR (01) Wed 01/26/2011 05:56:33 PM : [standard-Cleanup][08.50.E9-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 05:57:20 PM : [iNST-SRX ] 02 50 08.50.E9 00.00.01 C7 13 00 LTOFFRR(00) Wed 01/26/2011 05:57:20 PM : [standard-Group][08.50.E9-->Group=1] Max Hops=3, Hops Left=1 Wed 01/26/2011 05:57:20 PM : [ 8 50 E9 1] DOF 0 Wed 01/26/2011 05:57:20 PM : [ 8 50 E9 1] ST 0 Wed 01/26/2011 05:57:20 PM : [iNST-SRX ] 02 50 08.50.E9 13.22.DC 41 13 01 LTOFFRR(01) Wed 01/26/2011 05:57:20 PM : [standard-Cleanup][08.50.E9-->ISY/PLM Group=1] Max Hops=1, Hops Left=0 Wed 01/26/2011 05:57:20 PM : [iNST-SRX ] 02 50 08.50.E9 13.22.DC 42 13 01 LTOFFRR(01) Wed 01/26/2011 05:57:20 PM : [standard-Cleanup][08.50.E9-->ISY/PLM Group=1] Max Hops=2, Hops Left=0 Wed 01/26/2011 05:57:20 PM : Duplicate: ignored Wed 01/26/2011 05:57:20 PM : [iNST-SRX ] 02 50 08.50.E9 13.22.DC 42 13 01 LTOFFRR(01): Process Message: failed Wed 01/26/2011 05:57:20 PM : [standard-Cleanup][08.50.E9-->ISY/PLM Group=1] Max Hops=2, Hops Left=0
January 27, 201115 yr When you factory reset the switch, did you remove it completely from the ISY? If not, this is what I would try. After the factory reset, read it to the ISY. Hopefully, it will continue to not control anything.
January 27, 201115 yr Author When you factory reset the switch, did you remove it completely from the ISY? If not, this is what I would try. After the factory reset, read it to the ISY. Hopefully, it will continue to not control anything. Yep, tried that too. Factory reset, delete from ISY and readded it. After readding the behaviour came back....
January 27, 201115 yr Apparently the Responders still have links to the Controller. Even if the controller does not have links to the responders as long as it sends a group broadcast the responders will respond. Create a new scene with the controller and responders. Then Delete that scene. How to Remove a link not recognized by ISY This is probably because you selected Keep Existing Links when you added the devices. Rand
