Issue with Enable Internet Access
I am unable to enable internet access since my ISY99i locked up and my PLM fried. So, I did a software update and I get the same results. The funny part is I can access the ISY remotely but when I try to turn a device on/off I get an unable to connect screen. Has anyone ever had this issue before?
Did you replace the PLM? If the PLM was replaced. Did you use the Restore Modem PLM choice in File Menu to get the replacement installed correctly?
I did the restore PLM in file menu when I received the new PLM. The funny part is I just tried to enable the acces and it works fine now. Not sure what the issue was. Thanks for your help!
