AT&T to end email-to-text ×
ISY-26 Admin Console Java Error
Shinshi
I have just setup an ISY-26 and it is connected to my network. I can access it through my browser, but when I go to the Admin Console, I see an "Error: Click for Details".
I've looked at the details, but it doesn't mean anything to me, so not sure what I need to do to correct it. Any ideas?
Here is the error details...
Java Plug-in 1.6.0_19
Using JRE version 1.6.0_19-b04 Java HotSpot Client VM
User home directory = C:\Documents and Settings\peter
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
load: class com.universaldevices.client.ui.UDClientApplet.class not found.
java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed:http://192.168.1.103/com/universaldevices/client/ui/UDClientApplet/class.class
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: com.universaldevices.client.ui.UDClientApplet.class
... 7 more
That worked for me. The version number was the latest already, but one of those things corrected the Java error and I have no problem now accessing the ISY admin console.
Thanks Rand!
