EZSwitch30 Compatibility?
I don't think it has been added to the database yet but with it being only a single I/O device it would be an easy add for the guys.
It might work even so, but not show you what it is when you linked it.
Thanks for the reply.
I have ordered it. I will post my findings.
If it does not link, I can use it in X-10 mode until it is supported.
In Ken Millers InHomeFree I called mine a ApplianceLinc and it worked fine.
I believe HouseLinc Desktop also could control it but was called unknown device type.
I should have sometime to try it with my ISY-26 shortly.
Will report what I find.
DEGoodrich,
This device is not supported!
Brian H, please do let us know what you find. In most cases, for devices that are unsupported we simply use on/off metaphor.
