How to set a program so it doesn't run more than once a day
I have a "raining" program that e-mails me if it is raning at the house using the weather module. The problem is that the program keep alerting me constantly. I want it to just do it once a day. I tell it to stop the program, but it is obviously restarting, and I don't know why.
I am obviously missing something here, but I don't quite understand what it is... It is a simple program, and it is listed below:
From 12:10:00AM
For 23 hours 45 minutes and 59 seconds
And Module 'Climate' Rain Today > 0 "
Send Notification to 'e-mail'
Stop program 'Raining'
Hi smileyw,
The trouble is every time WB updates status and rain today is > 0" your program turns true and runs. Having the Stop Program at the end doesn’t really do any good for future program runs.
At first I was thinking you would need 3 programs, but I think these 2 might do the trick.
Program Rain Today:
       From    12:10:00AM
   And Program 'Rain Email Flag' is False
       Run Program 'Rain Email Flag' (Then Path)
       Run Program 'Rain Email Flag' (Else Path)
Program Rain Email Flag:
       Send Notification to 'Email' content 'default'
Once the WB reports Rain Today > 0†then the program Rain Today will turn true (as long as it is within the time frame and Rain Email Flag is false). At which time Rain Today program will run Rain Email Flag program which will then email you. Once the flag program is turned true it will stay true until the program Rain Today turns false (or the ISY is rebooted). Then the process can start all over again the next day.
This should work, but I haven’t tried it out so – use with caution :D .
Tim
Wouldn't I need to reset the flag at midnight somehow?
Well, I believe the Rain Today program would turn false once the clock strikes 11:54PM and stay false until 12:10AM and WB reports rain today > 0".
But now that I am thinking about it more though... I think that if WB reports rain today > 0" while the time is in the off period (11:54PM - 12:09:59AM) the two programs will cycle back and forth against each other.
So it looks like 3 programs will be needed.
Program Rain Today:
       From    12:10:00AM
Rain None Today:
       From    12:10:00AM
   And Module 'Climate' Rain Today is 0 "
   And Program 'Rain Email Flag' is True
Tim
I use three programs. I get one notice when Rain Rate >0. When Rain Rate =0 for at least 10 minutes the program is reset. I have WeatherBug update every 60 seconds.
Rain Rate
       Module 'Climate' Rain Rate > 0
   And Program 'It is Raining' is False
       Run Program 'It is Raining' (Then Path)
This program will only run if it hasn't rained in 10 minutes (10 updates).
Rain Rate Not
       Module 'Climate' Rain Rate is 0
   And Program 'It is Raining' is True
       Wait  10 minutes
       Run Program 'It is Raining' (Else Path)
It is Raining
       Wait  10 seconds
       Send Notification to 'Text to Blackberry'
Rand
Rand
Even more elegant :)
Actually, this is has all been really helpful to teach me how to do programming on the ISY.
Tim's answer is more relevant to "Once a Day", which was your original question. A gold star to Tim today!
Not really, becuase the Weather resets at midnight back to zero, so it essentially is the same thing.
Its raining here today, so we will see if it works.
Here's another take with an eye towards simplicity. No ELSE branches in any of these programs (of course).
Program 1: RainNotifyFlag (no code)
Program 2: SendNotitifcationOnRain
Module 'Climate' Rain Today > 0.2 " (some reasonable threshold)
Run Program RainNotifyFlag (Then Branch)
Program 3: ResetRainNotifyFlag
Time is 12:10:00 AM (sufficient time for module to reset values to 0)
Run Program RainNotifyFlag (Else Branch)
In my mind, simple is the most elegant.
Rain Rate
Rain Rate Not
       Wait  10 minutes
It is Raining
       Wait  10 seconds
Rand
So this sort of works, but the "It is Raining" doesn't ever seem to go to false. In fact, if I just run the "else" of that program manually, it still doesn't go to false. Is there something I need to do in the else to make it go false?
W
In Program Summary tab, what does ISY report the status of those three programs as?
In the Configuration>Climate tab what is the current Rain Rate amount?
And, did you want Rain Rate or Rain Today? In your original example you used Rain Today.
I would look at the conditions in the first program. When you force the flag false, the first program must be turning true and running which in turn turns the flag true.
Watch the run times in Program Summary tab for those 3 programs and run Else on the flag.
Tim
