March 15, 201115 yr Help! I can't figure this out! Simple example: Keypadlinc=C=closet1 D=closet2 I want Keypad B=to toggle OFF C+D and have the LED be on when either Closet C or Closet D are on and off when they are off. Somehow, program I write in ISY99i for B is affecting the C or D programs.
March 15, 201115 yr Help! I can't figure this out! Simple example: Keypadlinc=C=closet1 D=closet2 I want Keypad B=to toggle OFF C+D and have the LED be on when either Closet C or Closet D are on and off when they are off. Somehow, program I write in ISY99i for B is affecting the C or D programs. Select button B on the device tree and click the Buttons Toggle Mode. Select button B and click the Toggle On/Off button. Select OFF. Now make sure you have a Scene that has button B as controller and buttons C and D as responders only. Create a second scene that has button B as responder. Finally, create a program that says if status closet light 1 is on or status closet light 2 is on, then turn on that second button b only scene.
March 16, 201115 yr Author Also, does it matter if 2 buttons have Control? C - control closet light on/off B - master control closet lights OFF
March 16, 201115 yr Don't think so. B is shutting of C LED, but not C's load (closet1) Insteon commands don't cascade from one controller to another controller to another responder. If you want the Closet light to turn off when you press B, you have to link the closet as a responder to the scene controlled by button B.
March 16, 201115 yr Author Final Idea: Is it possible to control the MAIN LED independent of the load? I want it to be as night light, ON when light is off and Vice versa?
March 16, 201115 yr Negative, the main button will always correspond with the state of the built-in dimmer. If you wanted, you could use ISY programs to control other keypad buttons inversely with the state of the local load. What are you controlling with buttons G and H?
March 16, 201115 yr Author B=shut OFF C/D/E/F (LED B is ON when these are all OFF) - my pseudo nightlite C=closet 1 D=closet 2 E=bath light 1 F=bath light 2 G=kitchen H=Foyer So I got it all working great now.
