ISY-99i and Elk M1 Gold Question
I can currently set and disarm my Elk M1 Gold manually via the ISY interface. I'm wondering if it is possible to have a program within the ISY set my alarm automatically. Is that possible? I would really love to be able to set the alarm based on the status of a device within a certain time frame.
kd7iyt-
In the meantime, it is possible to do this using the Network module using the method outlined in this post. It's a bit technical, but once set it up, you can arm, disarm, and fire other ELK functions using programs.
The CRC calculator has moved to the Support Tools section of Elk's owner portal and is now called the M1 Software Developer's Tool.
I was bored so I took a look at the Elk RS-232 ascii protocol.
Michel,
If this is what you're using to create your Elk module (interfacing over RS-232 via a serial-ethernet converter) then you are 90% of the way there to interface with DSC alarms as well.
DSC's protocol is similar and in my opinion, less complicated.
