accessing html interface (non-java)
Are you speaking of accessing your ISY outside your home network? have you enabled internet access? When you do so, a window will pop up giving you the address. I recall, also, that address being available under the configuration tab.
You can't get to the admin panel, but you can see your devices and programs, etc....
When away, I access the ISY by pointing to the forwarded https port, and the java app pops up, no problem.
But sometimes you can't use java, so was wondering how to get at least get some access to the system. Will have a look at the config page.
* Orest
I can access the HTML page by just entering the http://IP Address:Port
or https://House IP Address:SSL Port if outside the house. Assuming the SSL port is port forwarded to the internal IP address.
If I access http://IP Address:Port/admin it brings up the Java console.
[sound of hand slapping forehead]
Oh, I see, it is just a matter of NOT selecting the admin console.
Sorry for the silly question.
* Orest
