Scene setup questions
I was wondering if someone could precisely describe what the Apply Changes To All Devices tick box, and the Copy Scene Atrributes from xxx button do:
* Orest
I am watching this thread for an answer to that ..........
My understanding for the first one is if you change the on-level for one device (for example) it will change the on-level for all devices in the scene.
One can only guess at the second one.
oskrypuch
I pulled the following explanation from the User Guide
Apply Changes To All Devices. This option will merge all Responder sliders to
one slider to make bulk changes easier. For example, if you want all responders
in a scene to turn on to 50%, simply check the Apply Changes To All Devices option
and drag the single slider to 50%.
Copy Scene Attributes From... As noted above, the ISY itself is also a
controller of every scene. If a controller within a scene should use the same
values as the ISY uses when controlling a scene, simply click this button to copy
the values from the ISY over to the currently selected Controller.
Lee
